dont do what i did
Old Nov 25, 2008 | 08:58 PM
crazy old mudslinger's Avatar
Default dont do what i did
my tranny got to where it was hung n a gear a few weeks ago on my 400ex, i pulled the motor(which involved takin a torch and cuttin the bolt that went thru the swingarm & motor)split the case & found a broke spring on the shifter shaft (problem found ,good deal) i put it back together &still not right & today the honda shop told me i couldve just pulled the clutch side & took the shifter shaft out & not split the case.i may have got the stops out of line & may have to split it again(its fun learin the hard way , aint it)
Old Nov 25, 2008 | 09:08 PM
cherokee99's Avatar
wow, that sucks. but you learn more from your mistakes they say
Old Nov 26, 2008 | 07:21 AM
HondaMechanic's Avatar
If your talking about the spring circled in red then yes the cases must be split to change it...
Old Nov 26, 2008 | 08:39 AM
yep thats it , but they told me that u can take it out with out splittin it , & after i got to thinkin bout it , its got a cut out section n the case and if u can get the return spring off u should b able to take it out the clutch side
Old Nov 26, 2008 | 02:48 PM
i just went & looked @ mine & i dont c any way of doing that , i think ill just split the case again
