Raptor 350 Knocking noise
Old Dec 3, 2008 | 12:00 AM
Ithy's Avatar
Default Raptor 350 Knocking noise
My son has a 2005 Raptor 350. Apparantly he ran it when it was low on oil and now it makes a ticking noise when it runs. I'm thinking that I need to adjust the valves, but have never attempted it. Is there anything else I need to look for while I'm doing the valve adjustments? I saw a video on Youtube on adjusting valves and it doesn't look like it's too difficult, but I would hate to put everything back together and find out that it's not the valves. Please help if you can. Thanks.
Old Dec 3, 2008 | 12:35 PM
beefy46172's Avatar
Loves To Ride!
There is a big difference between knocking and ticking, first of all. Second, the valvetrain on the YFM350 motor is noisier than most, but you really should adjust the valves on a fairly regular basis. I would go ahead and take it down and check them out to make sure they are still within spec, and if so, let it rip.
Old Dec 3, 2008 | 12:55 PM
TLC's Avatar
TLC
Does it only knock at idle? Give it just a bit of throttle and the knocking goes away? My 89 350 Big Bear (same 348cc motor) did that for years and years . If your uncomfortable doing your valves just get the dealer to do it, I don,t think they charge that much to do it.
Old Dec 3, 2008 | 02:12 PM
Ithy's Avatar
Thanks for the response fellas. It is in fact a ticking noise and it doesn't happen just when I accellerate. I can hear it as soon as I turn it on. It has always been a little on the noisy side, but not as bad.
Old Dec 3, 2008 | 05:56 PM
91Warrior357's Avatar
yea i bet there just off spec a little bit, specially with the oil thing when they get hot like that they will start to go out of adjustment. just try re adjusting them
Old Dec 3, 2008 | 09:19 PM
beefy46172's Avatar
Loves To Ride!
Yeah ticking is just the valves then, sounds like they just need a good adjustment job.
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
black_thunder
Sep 22, 2015 07:59 PM
