Extra light socket attached to taillight (sp500)
Old Dec 3, 2008 | 11:58 PM
Hockeyplayer00's Avatar
Default Extra light socket attached to taillight (sp500)
I'm talking about the taillight harness. There's the brake light one and then It looks like there is a reverse light but there's no light in it. What can I put in there? How would I go about putting strobes in it? What size light will fit? What is it for? If I do put a light in there when will it turn on?
Any help would be great.....would also like to know how to put strobes into taillights....thanks!!
Old Dec 4, 2008 | 12:19 AM
plumbob's Avatar
The bulbs that fit in the sockets are GE 912.The switch from polaris is pn#4011074.If you take the pod off there are cutouts underneath it.There's also a plug in the pod that plugs onto the switch.
Old Dec 4, 2008 | 01:25 AM
Charlie's Avatar
There is a kit from Polaris #2876090 that is the worklight kit. Includes two 13 watt bulbs and a switch.
Old Dec 4, 2008 | 07:17 AM
700 sportsman's Avatar
you can use the GE 912's, but the GE 921's are brighter, you also can use almost any old switch, I used a toggle switch with a rubber boot/nut to make it more water proof, I installed it under the pod below the headlight adjustment wheel
Old Dec 4, 2008 | 07:18 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you will see the plug harness in the pod for the switch as well which will give power to the light sockets
Old Dec 4, 2008 | 09:55 AM
Rutcutter's Avatar
I may have to switch my rear work lights out to a GE921,always can use the extra light. Thanks for the tip. [img]i/expressions/face-icon-small-cool.gif[/img]
Old Dec 4, 2008 | 04:53 PM
they still won't compare with your HID's thought lol
Old Dec 4, 2008 | 06:53 PM
Thanks everyone, that really helps....since you're at it...what HIDs will go in the headlights?
Old Dec 4, 2008 | 07:06 PM
Rutcutter's Avatar
Its the same 880 bulb as the 800's..
Old Dec 4, 2008 | 08:15 PM
DCT's Avatar
DCT
Banned
<div class="FTQUOTE"><begin quote>Originally posted by: 700 sportsman
you can use the GE 912's, but the GE 921's are brighter, you also can use almost any old switch, I used a toggle switch with a rubber boot/nut to make it more water proof, I installed it under the pod below the headlight adjustment wheel</end quote></div>
Excellent tip. Think I'll change mine out to the 921's... after I use the ones I just put in a couple times. LOL
