engine change and breather box removal
Old Dec 5, 2008 | 09:25 AM
football55's Avatar
Default engine change and breather box removal
My son has kazuma 110 baby falcon he rode it with out checking oil motor ocked up. I replaced with coyote 110 go kart motor which is the same accept it is D-N-R instead of 1-2-3-N-R. I want to remov breather box that comes on falcon 110 and replace with a regular uni-filter.. Does anyone know what i need to do.
Old Dec 8, 2008 | 06:28 PM
rjdad's Avatar
the main issues is making sure that the uni is on the carb and that it does not have any air leaks. All of the air needs to pass through the filter. sounds like you may have to fabricate somewhat to make it work. There is not more that can be said...using your imagination and coming up with a solution is all you need to know.
Old Dec 9, 2008 | 09:23 AM
football55's Avatar
Thanks for the info, I was asking because iwas told i would need to move needle inside carb up slots
Old Dec 9, 2008 | 10:47 AM
rjdad's Avatar
I was told that the relocation of the filter on a stock motor should not affect the performance of the machine. Try that before you do mess with the carb.
Old Dec 9, 2008 | 11:09 AM
football55's Avatar
Thanks, that was my thinking also, i was told may have to adjust air mixture screw but no adjustments to carb itself
Old Dec 9, 2008 | 01:08 PM
hotblooded's Avatar
I think that going to a pod filter and away from stock air box you may need to re-jet. They breath much easier so you may need to go up on the main jet. If you are using a Uni they should have a tech line, give them a call and get their opinion.
tiresharkdbb
Sep 3, 2017 02:06 AM
scaldwellk
Jun 19, 2015 05:08 PM
Rtgjje5
Jun 16, 2015 08:23 AM
blackwolf
Jun 7, 2015 08:05 AM
blaze_master
May 26, 2015 11:18 AM
