No power
Old Dec 11, 2008 | 07:16 PM
kaw550's Avatar
Default No power
I finally got the quad to a point where it will start and idle.
I did this by turning the mixture screw almost all the way in (air box off).
I thought I had it running right until I got on it and tried to move it. If I give it to much throttle it just bogs. Could turning in the screw too far damage the engine?
I did a search on this site and found it could be the crankcase seals. I have changed them on snowmobile engines but not on an atv. I know on my sled I can test them with carb cleaner. Is it possible to do the same test on the atv or are they covered? How big of a job is it to change the seals?
I need to have it running in 14 days!
Not to mention it is in the basement and I can only work on it after 9 PM.
Old Dec 12, 2008 | 11:28 AM
LT80's Avatar
LT80 Expert
Default No power
Did you clean the carb? Sounds like a plugged main jet.
Old Dec 12, 2008 | 06:30 PM
kaw550's Avatar
Default No power
I cleaned it twice. I made sure i can see through the jet.
It looks pretty good.
There is no air cleaner on the carb. I am sure it would restrict airflow and make it richer but I can't imagine it would make that much of a difference.
I also removed the electric choke and tested it.
I even dropped the clip on the jet needle to try and make it richer.
I looked at the reeds. They looked fine.
I sprayed carb cleaner at where I think the crankcase seals are located and I didn't notice an rpm drop.
I am stumped.
Old Dec 12, 2008 | 06:50 PM
LT80's Avatar
LT80 Expert
Default No power
Hmmm... How about ignition? I know a few has fixxed similiar problems by pulling the flywheel and sand/clean the stator/flywheel.
The pipe plugged?
Old Dec 12, 2008 | 07:00 PM
kaw550's Avatar
Default No power
I didnt mention that there is no battery in it.
Does that make a difference????
Old Dec 12, 2008 | 07:35 PM
kaw550's Avatar
Default No power
The exhaust looked okay. I can take it off and try reving the engine.
Spark looked okay but it wont hurt to check.
I am starting to question the compression again. Although it does idle and rev a little . My gauge is shot. I will pick one up tomorrow.
I think I will try a new plug.
Old Dec 13, 2008 | 10:19 AM
LT80's Avatar
LT80 Expert
Default No power
The compression will tell alot.
Old Dec 13, 2008 | 11:27 AM
kaw550's Avatar
Default No power
I ran to Harbor Freight and grabbed a new compression tester.
The PSI is either 65 or 95. Let me explain, it comes with an adapter for 14 MM. If I use the adapter it measures 65 PSI. Withough the adapter, it still treads into the plug hole but it measures 95.
I assume I need the adapter and the compression is 65 PSI.
This is with new rings and having the cylinder honed.
I assume this means I need a new top end??
Ever use the $99 ebay kits?
Old Dec 13, 2008 | 11:34 AM
LT80's Avatar
LT80 Expert
Default No power
Well, the rings may not be seated but I never put rings in w/o a new piston. That's my choice. I know some like to re-ring.
Either way, yes, it's too low. Get yourself a nice stock piston/rings, gaskets and such from your dealer.
I don't use wiseco pistons unless I have to.
Did the guy that honed it measure the piston to cyl wall clearance?
MeadowlarkFarm
Nov 27, 2019 08:40 PM
salixair
Nov 3, 2015 08:25 AM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
