kazuma 50cc will not start
Old Dec 11, 2008 | 11:49 PM
77datsun's Avatar
Default kazuma 50cc will not start
I've tried everything, cleaned the carb adjusted the settings adjusted the values, checked the plug cleaned and regaped it. If i shoot a little starting fliud in the carb it doesn't matter the tone of the engine stays the same doesn't even want to start. Is there a chance that it could be electrical??
Thanks in advance, Dennis
Old Dec 12, 2008 | 02:05 PM
tys's Avatar
tys
i know you said you replaced the plug but did you check for a spark?
Old Dec 12, 2008 | 03:22 PM
77datsun's Avatar
Yes, real good spark.
Dennis
Old Dec 13, 2008 | 08:52 AM
kaw550's Avatar
How is the compression?
Old Dec 13, 2008 | 01:11 PM
77datsun's Avatar
Real good compression 132psi
Old Dec 13, 2008 | 03:01 PM
tys's Avatar
tys
Is the carb getting fuel? Is fuel getting into the combustion chamber (is your plug wet after cranking it a while)? I've had trouble starting one of our 50cc's and up until recently the only way I could start it was by removing the plug and spraying the combustion chamber with starting fluid. As of today we have absolutely no spark. Also, have you checked suction at the carb? remove the air cleaner assy and crack over the engine with your hand covering the carb, does it have any suction? While you're there check to see if the choke is operational.
Old Dec 13, 2008 | 05:44 PM
77datsun's Avatar
There is no suction on top of the carb or on the side where the air breather hooks on.
Old Dec 15, 2008 | 07:40 AM
tys's Avatar
tys
If there's no suction at the carb it will not draw any fuel into the intake/combustion chamber. Was your choke on or off at the time you checked it? If should be off (lever should be down). Did you check your spark plug after cranking it over a few minutes? Is it wet with fuel? If no, this reiterates the point made by checking suction at the carb. Your machine isn't generating any suction on the pistons down (intake) stroke. Couple things here - check the intake and seals at the head and carb for cracks/leaks. We had a cracked intake once that wouldn't allow any fuel to be drawn into the combustion chamber. Also, check your valves one more time, making sure you're at TDC and that you put those big shiny caps on when done. There's a procedure floating around the net somewhere.
Old Dec 15, 2008 | 09:52 AM
lt250 4x4's Avatar
ANY time I have a problem witht he engine getting fuel.. I take off the air fiter and hold my hand over the carb opening and then crank it. That usually gets its started atleast once even if I have low compression.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
merryman
Jun 27, 2015 03:31 AM
1000gade
May 27, 2015 12:37 PM
2punksdad
May 23, 2000 01:46 AM
dcoleman
Oct 5, 1999 01:34 AM
