Hybird 150 Valve adjust
Old Dec 13, 2008 | 06:36 PM
Predatornut's Avatar
Default Hybird 150 Valve adjust
I have a Hybird 150 for my son. It has never idled well, and seems to have little power. I read here somewhere a while ago about the carb adjustments, and setting the valves. Someone had a post about how to adjust and to what spec. I have it in a shop right now getting worked on and they don't know to what to adjust the valves. Does anyone know or have a link to the post on how to do it? Thanks in advance.
Old Dec 13, 2008 | 07:12 PM
Coloradotrailrider's Avatar
My GY6 150 service manual says 0.08" or .12mm for the valves, engine is to be adjusted cold.
Old Dec 13, 2008 | 07:37 PM
LynnEdwards's Avatar
Electrical Expert
Obviously the 0.08" spec is wrong. That is over 1/16 of an inch! By the way my service manual says the same thing - it is just a *big* misprint.
0.12mm is 0.005", and that sounds a lot better. Here is an interesting link that has a step by step pictorial guide for the 150cc GY6 engine:
http://www.scooterforumonline....c1c%202ad&topic=1326.0
Old Dec 13, 2008 | 07:48 PM
You are awesome! This is exactly what I needed! Thanks so much!
Old Dec 14, 2008 | 10:33 AM
Thanks for catching that LynnEdwards, I hate giving bad info. I should have realized it had a missing zero, not to mention it didn't equal the 0.12mm.
Old Dec 17, 2008 | 12:55 PM
Electrical Expert
<div class="FTQUOTE"><begin quote>Originally posted by: LynnEdwards
[snip]... Here is an interesting link that has a step by step pictorial guide for the 150cc GY6 engine:
http://www.scooterforumonline....c1c%202ad&topic=1326.0</end quote></div>
The link above used to work, but apparently it moves around so that you must access it though the main page. Go to:
http://www.scooterforumonline.com/
Then select Chinese Scooter Forum and look for Valve Adjustment "Sticky" post near the top. Even though this post is for a scooter the engine it is identical to the 150cc GY6 engines used on ATV's.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
