polaris sportsman 500 wont start
Old Dec 14, 2008 | 08:20 PM
tomssportsman500's Avatar
Default polaris sportsman 500 wont start
i have a sportsman 500 my son was riding and it stalled on him in a hill when it rolled backwards it sounded like the motor turned and now it wont start can anyone help me
Old Dec 14, 2008 | 08:57 PM
Check simple things first,such as plug,does it have spark? If not replace plug,check with plug in cap against valve cover for fire. If no fire,remove plug cap,check for spark on bare wire to metal to eliminate cap. Plus air filter and air box for gas or oil (can happen in climbing,saturating filter and stalling out?
Old Dec 14, 2008 | 09:08 PM
he was riding it it stalled and rolled backwards in forward gear it sounded like the motor was turning when it was rolling backwards and now it wont start.it has compression and spark
Old Dec 14, 2008 | 09:59 PM
Rowe's Avatar
So do you think something happened to it while it was rolling backwards, or something happened first causing it to stall and then it just rolled backwards?
I would check to see if it's getting fuel, air, & spark. Does it have gas, if yes how about the fuel filter? How cold is it where you are? Anychance you got some water in your fuel and maybe the fuel fiter froze up? Give us some more clues and I'll throw some guesses then OPT will let you know whats really wrong with it and how to fix it.
Old Dec 14, 2008 | 10:06 PM
it cranks over fine im not sure when it happened but i know when he got to the bottom of the hill he tried to start it and it just cranked over i tried starting it with the choke did not help it is getting good spark i was afraid it may have jumped time or something like that not sure on weather or not its getting gas. should i try spraying card cleaner in the card to see what it does.
Old Dec 14, 2008 | 10:42 PM
lovmudd's Avatar
You say it has compression and spark so yes, I would try supplying some gas to see if it will fire. I would use gas not carb cleaner. Use an oil can, with gas in it to either squirt a couple of good shots in the spark plug hole or shoot it down the carb throat. Take precations by having a fire extinghiser on hand and be extra careful not spill gas all over the place.
Old Dec 14, 2008 | 10:47 PM
i will try it tomorrow and see if it will fire. i just didnt want totry it incase it would mess something else up
Old Dec 14, 2008 | 11:05 PM
Wenty's Avatar
I hate to ask, but....is there gas in the tank? Simple things first! Fuel accidently get shut off? Kill switch? Believe it or not it's been know to happen...don't ask how I know!!
Old Dec 14, 2008 | 11:10 PM
yea there is gas in tank, yea fuel is on,yea kill switch is on run position
Old Dec 15, 2008 | 12:57 AM
Rickeyparker's Avatar
Hey it could have broken the flywheel key.
