Sportsman 500 Spark plug
Old Dec 17, 2008 | 08:36 PM
Srcharlz's Avatar
Default Sportsman 500 Spark plug
Dumb question: How do I get that spark plug outta there?
Old Dec 17, 2008 | 09:35 PM
Koerbs's Avatar
Pull off the cap and the plug is down in there. Use your plug wrench that came with the atv to take it out.
Old Dec 17, 2008 | 11:53 PM
Srcharlz's Avatar
Ok... do I have to take the gas tank off? Can't even reach it...
Thanks
Old Dec 18, 2008 | 12:00 AM
Sportman 97's Avatar
nope. take the side cover off. (side with the shiffter) use you sparkplug wrench and your done.
Old Dec 18, 2008 | 12:28 AM
Srcharlz's Avatar
I gotta tell you guys, I must be the world's biggest tard, cuz I can't even figure out how to get the cap off... doesn't even seem possible... (???????) No way I could get my hand in there...
Old Dec 18, 2008 | 01:14 AM
1st take your seat off. then take your side panel off, fine your spark plug wire to the spark plug, pull up until it comes off, make sure you are pulling on the boot and not the wire. then use your spark plug wrench that came with the ATV, it will fit right down in there. make sure its all the way down and turn to your left. replace the new plug the same way. i always use never seize (just a little) on the new plug. next time you change it it will come out no problem.
IF YOU WANT TO HAVE MORE ROOM TWO BOLTS UNDER THE SEAT AT THE END OF THE GAS TANK. TAKE THEM OUT WILL GIVE YOU EXTRA ROOM, BUT YOU REALLY DON'T NEED TO DO THAT.
Old Dec 18, 2008 | 07:00 AM
Srcharlz's Avatar
My trouble is i can't reach the plug wire, or the boot...??? What am I doin wrong??
Thanks for the help!!
Old Dec 19, 2008 | 04:36 AM
user493's Avatar
Moto Psycho
After you pul the right side cover off you should be able to reach in and grab the spark plug boot. I have big hands but I can still reach it.
Old Dec 19, 2008 | 02:10 PM
Hotdogmb's Avatar
your spark plug wrench has a deal on it to lift up on the spark plug boot.
Old Dec 19, 2008 | 02:18 PM
Deerkiller's Avatar
Is that what the end of that is for, I've been opening Corona's with it.
