E-ton txl 50 wont run
Old Dec 20, 2008 | 05:05 PM
MartinD's Avatar
Default E-ton txl 50 wont run
Just picked up a txl 50. we cleaned the carb and it fires but wont start and it seems to be dumping some oily residue out of the spark plug hole.we capped of the oil injection and just mix the gas/oil. we pull the plug and spin it over to blow that oily stuff out.reinstall the plug and it will try to start on the first try then nothing.we repeat and ge that same stuff coming out of the plug hole.any ideas?i hate to throw this thing away as its in good shape.
Old Dec 23, 2008 | 03:35 PM
leadsled01's Avatar
I would check the compression. I think it should have around 100psi.I have a 90cc eton and it was a bear to start. Installed new jug/piston and rings from a kit they sell on ebay for $170. Fixed mine.
Old Feb 13, 2009 | 05:03 PM
smithtf's Avatar
Someone gave me one that didn't run. Same symptoms as you mention. Noticed there wasn't anything coming out the tailpipe when we cranked it. Pulled off the exhaust and it fired right up. Found it was completely plugged with mud by wasps. Filled it with water and let it soak for 40 minutes to soften the dirt.
Old Nov 20, 2013 | 03:00 PM
milamcreekmx's Avatar
Awesome words of advice, check this first will find this to be your problem. you are a genius!
spike99
Apr 28, 2004 01:23 AM
GE4x4
Mar 20, 2004 02:37 AM
OSURobsQuad
Feb 28, 2004 12:27 AM
fishslab
Feb 12, 2004 02:18 PM
westexgt
Feb 2, 2004 12:45 PM
