NEED HELP BAD PLAESE HELP 400EX HELP
Old Dec 21, 2008 | 12:24 AM
honda400exracer3's Avatar
Default NEED HELP BAD PLAESE HELP 400EX HELP
I HAVE A 2003 HONDA 400EX IT IS COLD OUT SO I TOOK THE BATTERY OUT TO CHARGE AND I WHEN TO PUT BACK IN ALL CONNENTED AND EVERY THING WITH CLEAN CONNENTIONS AND I GET NOTHING NO NUTRAL LIGHT THE HEAD LIGHT AND TAIL LIGHT DONT EVEN LIGHT I GET NOTHING WHATS UP I CHECKED THE FUSE AND CONNENTIONS AND
WHAT DO I CHECK AND DO PLEASE HELP
Old Dec 21, 2008 | 12:28 AM
cherokee99's Avatar
1 are the conections on the right terminals?
2 is the battery grounded to the frame?
3 are you sure the battery has some juice?
those are my guesses
Old Dec 21, 2008 | 12:32 AM
YEAH I check all that i am going to again but the fuse is good the thing is i put a jumper box on it to and still can get any light to come on and or eletric start to work
Old Dec 21, 2008 | 12:40 AM
cherokee99's Avatar
see if mabe you can jump the cylinoid on the starter with a skrewdriver. get a volt meter and see if you can find a current giong to anything? that sounds wierd, there has to be something els going on... keep checking every fuse and test every wire for a current
Old Dec 21, 2008 | 12:41 AM
ok i will tomorrow thank you good advise ill keep you posted thanks
Old Dec 21, 2008 | 12:48 AM
Old Dec 21, 2008 | 07:17 PM
TNHondaMan's Avatar
really just sounds like your not getting a proper ground,if your fuses are good, more than likely just ground somewhere else and make sure its clean.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
