Kymco 50 Mongoose will not start
Old Dec 21, 2008 | 09:21 AM
durhamatv's Avatar
Default Kymco 50 Mongoose will not start
She was not run for three years. Put in new battery and gas and it would crank and run for only 30 seconds. This would repeat every time I tried to start and run the atv. I figured the carb jet was gummed up so I disassembled and soaked ther carb. Put the carb back together and now she will not even start. Not even when I give it a short burst of starter fluid. Spark is good but the plug is very wet.
Any ideas out there? Thanks.......Mike
Old Dec 21, 2008 | 10:52 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
Did you clean the gas tank out so no left over yuck is not going into your clean carb?
Wet plug means it's flooded by attemting to start and hitting the throttle OR the float is allowing fuel past (possibly yuck in the float seat/needle).
You may need to clean the carb again.
Let's go from there. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 21, 2008 | 01:41 PM
durhamatv's Avatar
Thanks......I will give it another go on the cleaning.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
