Help with oil change Loncin 110
Old Dec 24, 2008 | 04:25 AM
pfbiker's Avatar
Default Help with oil change Loncin 110
Hi everyone, I started doing an oil change on my daughters 110 quad and undid the wrong bolt to drop the oil and a spring and some sort of oil way shaft or pin came out . Unfortunatley i didnot see the way it came out and would like some help to sort this problem. Can anyone help with the correct reasembly of these parts as i dont want to cause any damage to the engine.
thanks guys.
pfbiker
QLD Australia
Old Dec 27, 2008 | 10:30 AM
woodchuckie's Avatar
The rod goes in first then the spring and the plug holds it in. You should be able to see where the spring fits on the plug. The whole assembly is the timing chain tensioner. I've been there and done that.
Old Dec 27, 2008 | 11:39 PM
Jessie_atvruns's Avatar
The above drawig shows the structure of the "Jack in the box."
Old Aug 23, 2014 | 05:39 PM
SEG's Avatar
SEG
You guys are life ROCK!! 2days tring to find the answer to this very question. THANK YOU
Old Aug 24, 2014 | 12:48 PM
Done the same thing myself with a Buyang 70, luckily I did see how the bits came out.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
LemonTea
2) Chassis problems..
Oct 2, 2015 03:50 PM
Jackg17
Sep 26, 2015 09:30 PM
