Predator Shock Adjustment
Old Dec 24, 2008 | 09:55 AM
brianvabeach's Avatar
Default Predator Shock Adjustment
I just picked up a Predator. It has the adjustable (clicker) rear shock. What exactly does the Clicker do???? Is that for the recoil of the shock????
Old Dec 25, 2008 | 12:51 AM
Cutfoot's Avatar
That should be your rebound adjustment. You should be able to tell the difference. Crank it all the way one way then push down on the rear end and watch at the speed that it returns. Do the same with it adjusted in opposite direction. You will see noticeable difference unless the shock needs to be rebuilt.
Old Dec 26, 2008 | 08:19 AM
ok thanks
Old Dec 26, 2008 | 10:29 AM
KQ400Pilot's Avatar
Take a look at: http://www.predatorowners.com/ ---lots of info there.
Old Dec 26, 2008 | 11:03 AM
awesome, thanks KQ
Old Dec 29, 2008 | 10:23 AM
Does anyone know the email address of the admin for www.predatorowners.com??? I have tried to register but cannot get a confirmation email sent to me. I have looked all over the site and cannot get a good poc for contact
Old Dec 29, 2008 | 12:35 PM
KQ400Pilot's Avatar
Do you use AOL? (I have edited out some non-essentional verbiage (ie, rants from the administrator)) --From the Pred Owners.com website:
AOL Users
because of the way AOL operates, it is very difficult to get email from this server to AOL accounts......As a result, AOL has chosen to block email from this system, thinking that it's a source of Spam. It is impossible to get the block removed Therefore, if you wish to be able to use this site, you will need a different email address. We recommend Yahoo, Hotmail, or any of the other free email systems.
If you're adamant about staying with AOL, then contact us privately and I can give you the two IP addresses of the servers this system uses in case you'd like to try to convince AOL to unblock them and LEAVE them unblocked.
Old Dec 29, 2008 | 12:54 PM
No not on AOL. I can get to the site fine and browse around, just cannot see anyway to contact anyone in charge of the site.
Alex G.
Sep 19, 2015 06:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
Elkaholic
Sep 6, 2015 02:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
