slow tire leak problem
Old Dec 25, 2008 | 03:03 PM
nottelybill's Avatar
Default slow tire leak problem
this may sound like a dumb question but on my 2006 rancher my left front tire keeps slowly leaking down. I looked for any nails or such and I couldn't fine any. Then i spayed soapy water all over the tire and could still detect no leaks. Any ideas. also checked valve steam. maybe i should just put a tube in it as my son suggested
Old Dec 25, 2008 | 06:23 PM
wolverinekid350's Avatar
i had the same problem with my bike i think its just some crapy tire copany what brand are the tires
Old Dec 25, 2008 | 07:18 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
It isn't that uncommon to have a tire with a slow leak. Usually, it is the bead. When mounting the tires, a little bit of the rubber on the bead gets shaved off by the tire irons, and never seals up just right.
I run Fix-a-Flat in all my tires all the time! This takes care of any nail punctures I might get out on the trail, and will often also seal a leaking bead.
Old Dec 25, 2008 | 08:16 PM
ElBando's Avatar
I had some very slow leaks on my Rancher, could never find where the holes were located. The only way I found the source of the leaks was to way over inflate my tire, then use a soapy water solution ( dish detergent works great ). I found all my leaks that way. Don't be afraid to put the air in.
Old Dec 25, 2008 | 09:26 PM
cherokee99's Avatar
i run slime in leaky tires. fixes the problem, plus a little extra for when you do run over a nail
Old Jan 14, 2009 | 02:25 PM
Varty's Avatar
ya til you have to change your tires and all that junk is in there lol...I work at a shop and have to change tires and nothing worse then doing one with slime in it OH GEEZ!!
Old Jan 14, 2009 | 03:32 PM
Seemer's Avatar
Does having any of those leak sealers in the tire effect the balance at higher speeds? like 40 or 50kmh
Old Jan 14, 2009 | 03:53 PM
ss97's Avatar
Lets Ride!
<div class="FTQUOTE"><begin quote>Originally posted by: Seemer
Does having any of those leak sealers in the tire effect the balance at higher speeds? like 40 or 50kmh</end quote></div>
ATV tires are never balanced....... You would never notice it in a million years while riding on dirt and rocks.....
Old Jan 14, 2009 | 04:52 PM
Red Rider
<div class="FTQUOTE"><begin quote>Originally posted by: reconranger
I run Fix-a-Flat in all my tires all the time! This takes care of any nail punctures I might get out on the trail, and will often also seal a leaking bead.</end quote></div>
No balancing problems, even at high speed. Run it in my street legal motorcycles as well....
Old Jan 14, 2009 | 05:32 PM
Seemer's Avatar
Thanks for the info, I had a flat during hunting this fall and had the plugs but no air!
Now I carry a small pump and will have fix-a-flat or slime.
