slow jet question
Old Dec 26, 2008 | 05:36 PM
cherokee99's Avatar
Default slow jet question
i poasted a while back that i ran out of richening adjustment (pilot jet) on my foreman 450. since the colder weather has struck i am very aware it is running lean. i ordred a larger #50 slow jet to replace the stock #45.
1. just makeing sure that the slow jet governs how much fuel is being put in the carb at idol-1/4 throttel. then the pilot jet can adjust that value as well?
2. is there any adjustment in the origional slow jet setting i am missing? im pretty sure you just skrew the slow jet in
like i said i just want to make sure im not overlooking anything. thanks alot in advance
Old Dec 26, 2008 | 09:17 PM
Doctorturbo's Avatar
GOT BOOST!
<div class="FTQUOTE"><begin quote>1. just makeing sure that the slow jet governs how much fuel is being put in the carb at idol-1/4 throttel. then the pilot jet can adjust that value as well? </end quote></div>Pretty much right on. I don't think the pilot jet goes all the way to 1/4 throttle though. Usually just off idle.
<div class="FTQUOTE"><begin quote>2. is there any adjustment in the origional slow jet setting i am missing? im pretty sure you just skrew the slow jet in </end quote></div>
Yep, about all there is to it.
<div class="FTQUOTE"><begin quote>like i said i just want to make sure im not overlooking anything. thanks alot in advance </end quote></div>
None that I can think of. Just go have fun!!
Old Dec 27, 2008 | 12:58 AM
cherokee99's Avatar
thank you doctorturbo 4 the quick responce! i was just makeing sure i hade everything strait in my head, its been a hectic holiday seasons! iv always been told pilot jet regulates your speed up to <u>about</u> 1/4 throttel. i would say that is true on my mechine, as soon as i go over 1/4 throttel i feel the needle rise and kick in. usually the needle jet opening is smoother no alot of mechines i ride.
thatnk alot!
Minimod
Sep 10, 2015 09:20 PM
essonlaker
Sep 10, 2015 01:12 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
black_thunder
Sep 6, 2015 04:41 PM
