DS 650 lte
Old Dec 29, 2008 | 03:24 PM
Bomb-s-quad's Avatar
Default DS 650 lte
which air filter can ? use ? becos air filter box is gone [img]i/expressions/face-icon-small-smile.gif[/img] when ? use other air filters on carb seat is not closing... K&N have a filter which will fit on my carb so that the seat can close down.. thanx
Old Dec 29, 2008 | 04:57 PM
SilverBomb's Avatar
SilverBomb has got an Addiction!
Default DS 650 lte
Yes indeed my man, K&N makes a filter that you can mount directly to your carb. You can buy it directly from Ron Woods. Clicky!!
Old Dec 29, 2008 | 05:40 PM
Default DS 650 lte
thanks for your help man..
Old Dec 29, 2008 | 11:31 PM
TheStir's Avatar
Started riding ATVs in 1974!
Default DS 650 lte
There are 2 K&N that fit as direct mount. RW sells the SN-2550 I run the SN-2560 this has one more inch of filter length.
Old Jan 2, 2009 | 01:11 AM
ERBEDS650's Avatar
Default DS 650 lte
Jeff Ross clued me in on the intake set up, clamp on for more peak top end HP , the stock intake snorkle for all around torque, both will require new jetting.
Im trying out a new micro filter that flows as or better than a K&N and filters like a foam filter, sucker is 9" long and has a vortex at the end of it, heard nothing but good things on large bore 2 strokes, so I am waiting on dyno time to get 2 quads done.
Old Jan 2, 2009 | 01:53 AM
TheStir's Avatar
Default DS 650 lte
Jeff says the cross over is around 6,000 RPM, in my testing on my build the high end gain more that more than offset the hit to the mid range.
Old Jan 2, 2009 | 02:02 AM
ERBEDS650's Avatar
Default DS 650 lte
I was interested more in a even pull from 3500 to 7500 rpmmine signs off at 8500
Old Jan 2, 2009 | 02:14 AM
TheStir's Avatar
Default DS 650 lte
Have you run it both ways to see how it behaves? I though the same as you until I testing it myself.
But its a moot point for this thread, the LTEs can't run the snorkle.
Old Jan 2, 2009 | 08:32 AM
Default DS 650 lte
SN-2550 - SN-2560 which one is direct mount on carb ?
Old Jan 2, 2009 | 11:47 AM
TheStir's Avatar
Default DS 650 lte
They both are, the SN-2550 is the one the Woods sells and the SN-2560 is the same in every dimension but the overall filter length is 1" longer for more airflow.
