honda trx 400 ex cylinder and pistion
Hello there, just wanting some advice if enyone has got any because i have run out of ideas! I have a honda trx 400 ex year 2001....
so enyways i have put a new cylinder and piston on the bike because it was burning oil when running! i have reseated the valves .. replaced all the seals in the top end. new head gasket, new spark pug new oil , adjusted the tappets inlet and exhaust .. set the timing to the "T" mark and to the marks on the cam shaft with the edge on the casing "top" and it seems to be getting fuel because it smokes when trying to start! and also back fires! compression is good!!!!!!
The only thing i dont understand is why it was running before with lower compression but now it has full compression and wont start
If anyone can help me out, please get back to me!
thanks for your time!
Danny
Danny
if u didnt take the gear out of the timing chain u may have it 180 out , ive had problems the last few weeks to get mine running and it was n the timing , but i tore mine all the way down and even split the case , did u make sure the word "out" on the timing gearis showing @ bout 3 oclock and with the lobes up ?then roll it over till they r down before u put the head on
HELLO AGAIN
Well i have sorted the timming out and is now set spot on every thing eles is good
there is only one problem it still does not start???? i'm think it mite be electrical now so does enyone know where to start before i start buying new cid boxes ,
Ignition Coil's,Regulator i;m not sure if eny one knows a common problem but there is a spark not a very good one i changes the spark plug but makes no diffrence
cheers danny
cheers danny
Will it start if you try and bump start it? Very possible that the plug is fouled out with all the failed attempts at starting it with the timing off.
yer i tryd to pull it with my car !! it doesnt even try a little back fire that was all
not sure if i shud replace the rectifier becuse i have been trying to star it with the battry charger i dont know if this could of damaged it or somthing else ????
cheers danny
cheers danny
First pull the sparkplug out and ground it to a bolt and cank it to see if it is getting any fire. Another problem could be your valves out of adjustment. You may want to check that.
