Engine running poorly on Kazuma
Old Dec 31, 2008 | 04:10 PM
PaulinKansas's Avatar
Default Engine running poorly on Kazuma
Kazuma Dingo 250cc ATV. Whenever I give it gas more than 1/2 throttle, the engine seems to sputter, cut out and otherwise not want to fire/run. It seems to run fine for 1/2 throttle and less. I've changed the plug, oil, cleaned the air filter, checked for good fuel flow in the fuel line, and found nothing. Could the problem be in the carb or the ignition? I'm somewhat mechanically inclined, but would like a direction to start looking for a solution.
Old Jan 1, 2009 | 12:54 AM
onebigzj's Avatar
I would pull the carb apart and go from there
Old Jan 3, 2009 | 11:55 PM
cowgirl's Avatar
If this is a 250 watercooled check the carb manifold as they are junk they split apart and then do not run right.
Old Jan 3, 2009 | 11:59 PM
onebigzj's Avatar
ya for got about that one. I already changed mine
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
scaldwellk
Jun 19, 2015 05:08 PM
brinkkl2000
Jun 11, 2015 12:46 PM
Jiggypete
May 30, 2015 07:55 AM
