Hammer Twister 250 electrics problem
[img]i/expressions/face-icon-small-frown.gif[/img]
Happy New year all. any advice mush appreciated!!
got a 2 year old Hammer 250 for the kids - 2 days of happy fun but then very erratic starting and now day 3 no spark at all.
bought new plug - no joy. I suspect coil but will check cutout switch.
Do any of you have any thoughts - perhaps this is a usual problem?
If it is the coil or other part where on earth do we source them? Are the Honda parts perhaps.I'm in the uk and no one seems to have much of a clue on this.
any help would be much appeciated.
thanks
thanks
Chris,
Is this a Hammerhead Twister 250cc Buggy?
I'm not very familiar with those. Buggy wiring is typically a lot different than quad wiring in the battery charging and lighting areas. The lights tend to run off the AC output of the low voltage high current winding of the stator rather than the regulated DC battery side (don't confuse this with the high voltage low current ignition power winding which is completely separate). Also the ignition systems on buggies are somtimes shut down by methods other than the kill switch, such as disconnecting the timing trigger signal, or removing the ground to the CDI.
To the best of my knowledge the hammerhead twisters do use only the kill switch connections for engine shutdown. I have a wiring diagram for a 2007 hammerhead 150cc buggy. And here is a problem: In an earlier post I said that the ignition systems of almost all quad engines run off an AC high voltage winding on the stator. Hammerhead buggies are one of the exceptions. Starting around 2007 (on the 150 cc engines at least) they started using special CDI's that ran on 12 volts DC instead of 80-250 volts AC off the stator. Before 2007 they used the standard ignition power winding on the stator and standard (easy to find) CDI modules. Whether this also applies to the 250cc engines I don't know.
Here is a place that knows a lot more about buggies than me:
http://www.buggynews.com/index.php
If you ask around there I promise you will get lots of help.
The reason for starting at the kill switch connection (checking for shorts while the engine is stopped, and measuring AC and DC voltages here while cranking) is that this measurement point is right in the middle of the ignition system. High voltage here means that the high voltage power supply in the CDI is working, which eliminates the the stator and ignition power stator wiring. In this case we would next look at the trigger pulse, the CDI itself, the coil and the spark plug. Lack of voltage at the kill switch connection would direct the effort to the ignition power input wiring of the ignition power winding on the stator.
As far as the ignition coil being the common failure item - this is not my experience at all. Ninety percent of all problems I've experienced or read about involve bad connections in the wiring rather than failed parts. Chinese connectors are awful. Most of the time I read about people who double and triple check the connections only to find out later that they overlooked the one that was causing the problem.
As far as sources for parts: eBay has had everything I needed for my 150cc quad. Buggynews has several parts dealers that offer good free advice and sell parts - shipping to London though is likely a problem because of transportion costs and customs issues. I'd try eBay Europe first.
Lynn Edwards
Lynn Edwards
Llnn
Impressive knowledge - thanks for the tips - I will brave the -5c weather outside and investigate as far as i can - yes checking those connectors makes a lot of sense.
Yes its a 250 Twister buggy. Wil;l try that site you sent.
Thanks for the help
C
Thanks for the help
C
Lynn
Re that Twister 250 electric problem.
Well I followed your advice carefully and went thru the wiring connectors in the box one by one - sure enough th 6 wire connector had a loose wire. 5 mins later running perfectly.
Thank you VERY much - you surely saved me aggro and money so i'm really appreciative. The internet really is an extraordinary tool.
Many thanks again
happy offroading
Chris
Many thanks again
happy offroading
Chris
Chocobamofo
Jul 10, 2015 07:46 PM
ranvette
Jul 4, 2015 06:13 PM
