Hard to steer with plow installed
Old Jan 2, 2009 | 01:00 PM
jpn800's Avatar
Default Hard to steer with plow installed
Like the title says, I have a 00 Sportsman 500 with a moose plow. With the plow off the machine runs and drives great. When I install the plow the steering becomes very hard and will pull hard to either side (in forward or reverse). Are the springs just overloaded? All my suspension and tie rods are in good condition also. Thanks for any input
Old Jan 2, 2009 | 01:15 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you are corect in thingkinf the suspenion is over loaded. you ned to have heabier springs to help w/ the load and maybe a small amount more air in the tires.
Old Jan 2, 2009 | 01:19 PM
DCT's Avatar
DCT
Banned
I would agree... the Moose plows are heavy duty... you'll need some springs. As stendori said... more pressure in the tires may help some.
Old Jan 2, 2009 | 01:28 PM
jpn800's Avatar
Where can I get HD front springs? All the ones I see are for the 05 and up.
Old Jan 2, 2009 | 01:46 PM
DCT's Avatar
DCT
Banned
Try here...
EPI
You could also look over at Highlifter's site
Old Jan 2, 2009 | 01:54 PM
jpn800's Avatar
Thanks, If I dont trade it up for a newer one I'll order a set of EPI's
Old Jan 2, 2009 | 03:00 PM
blkedoutsprtsman's Avatar
One thing to consider since you enjoy the ride before you hook up the plow.......some coil spring rate adjusters. I know they make them for my 08 and im sure there is something for your older sp.
Old Jan 2, 2009 | 03:19 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the problem is that the struts that polaris uses w/ their springs just arent designed to do alot of front end lifting(even w/ the newer models except the 09') and the only way to correct it is w/ heavier springs or putting in spring spacers to take up the slack from the famous front end sag(happends to most of them when you add extra weight to the front end)that happens over time. the adjustable spacers only give a very limited boost of 1" i think and since you have to pull it apart i would just get heavier springs or home made spacers. imo.
Old Jan 2, 2009 | 03:35 PM
true...ive heard that in past forums......so will it void my warranty if i replace the springs??? How about the ride, is it as smooth???
Old Jan 2, 2009 | 04:50 PM
DCT's Avatar
DCT
Banned
<div class="FTQUOTE"><begin quote>Originally posted by: blkedoutsprtsman
true...ive heard that in past forums......so will it void my warranty if i replace the springs??? How about the ride, is it as smooth???</end quote></div>
I doubt that it will void you warranty... Polaris has front end upgrade springs for your quad (and mine [img]i/expressions/face-icon-small-smile.gif[/img] ) too.
See here:
Polaris Spring upgrade
I bet they will stiffen up the ride. I'm sticking with my couple of spacers for now... I can take them out after the plowing season. [img]i/expressions/face-icon-small-smile.gif[/img]
