messed up predator
i have a 04 predator 90 that just wont start for me. when it started gettin cold i thought the throttle cable broke. i took of the carb and got the cable to move, but now when ever i try to start is the starter moter just sings and it doesnt even think about starting.
what is wrong? i would be greatful for any helf>
First check to see if you are getting spark. Also make sure your choke is operating. If both are fine then your carbs are most likely gummed up. The fuel now has alot of ethanol in it and goes bad quickly. This clogs up the small jets easily. Try some Amsoil Power foam in the carb inlet, 90% of the time it gets the crud out without removing having to remove the carb.
Elkaholic
Sep 6, 2015 02:44 PM
