400EX lugs on a Predator? + Choke Question??
Old Jan 5, 2009 | 09:57 PM
cway77's Avatar
Default 400EX lugs on a Predator? + Choke Question??
Just purchased a set of snow tires for my Pred that are mounted on factory Honda rims. Once I got these home noticed that I needed tapered lugs. Will the stock Honda tapered lugs work on the Predator lug bolts? I have looked everywhere for sizes but can't seem to find anything.
Also starting to think my choke isn't working due to my Pred not starting very good in the cold. There is a small narrow brass bolt that threads into a bigger brass nut that attaches to the carb, do I have to take the big nut attached directly to the carb off to clean the plunger should it be dirty and causing this problem? I took the smaller narrow one off to try and clean it but it wouldn't come through so not sure if its because of how dirty it is or because its not the right way. Would appreciate any help as this thing sucks starting in the cold and its an 07. Just had my valves adjusted so I know its not that. Thanks very much!
Chad
Old Jan 6, 2009 | 09:41 AM
cway77's Avatar
Anyone? Please?
Old Jan 6, 2009 | 09:57 PM
Lugs on Honda will be metric,but most Polaris machines are standard pitch studs and nuts. We order sets for customers all the time,or you can check online. Choke plunger usually gets gunked up,You can just remove top cap and diaphram on carb to see the plunger and spray a little carb cleaner or penetrating lube in cavity to try to get to working,OR just unscrew from carb,remove and clean. Good luck
Old Jan 6, 2009 | 10:29 PM
cway77's Avatar
THANK YOU VERY MUCH!!!!!! ITS MUCH APPRECIATED
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
yambam13
Jul 4, 2015 01:49 PM
