lt80 ticking
Old Jan 11, 2009 | 09:54 PM
kjm 42's Avatar
Default lt80 ticking
my youge blokes lt80 makes a ticking noise,it seems to be coming from the clutch area but its hard to say,if i lift the back wheels of the ground and rev it its not there,it only seems to do it under load,i know thats not much info but i was woundering if it maybe a common thing with them,any info would be most helpfull.it doesnt seem to affect the bike(yet)
Old Jan 12, 2009 | 09:11 AM
LT80's Avatar
LT80 Expert
Welcome to the forums. [img]i/expressions/face-icon-small-smile.gif[/img]
I'd maintenence the clutchs to see if something is up in there.
Oil in gearbox?
Maybe a compression test to see if the piston is wore.
Old Jan 13, 2009 | 01:44 AM
kjm 42's Avatar
thank you top end is still pretty new,but i didnt even know it had oil in gear box i thought it was a dry clutch,i better go & have a better look
thanks for the help,
kev.
Old Jan 14, 2009 | 11:29 AM
LT80's Avatar
LT80 Expert
There is the clutchs and a gearbox.The clutchs are dry but often a cause of trouble if not maintained.
Old Jan 16, 2009 | 01:33 AM
kjm 42's Avatar
cheers lt80 i changed the oil and put some grease in the back nipple,we'll see how that go's.can the clutch cover be taken off with the motor in the bike.
thankyou,
kev.
Old Jan 16, 2009 | 11:37 AM
LT80's Avatar
LT80 Expert
Yes, the clutch cover comes off w/motor in machine.
remove all 4 footpeg bolts so you can move the pegs back and forth to get the bolts out/cover off.
Don't forget to remove the bolt at the 3 O'clock position on the lil cover to get the clutch cover off. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 17, 2009 | 12:11 AM
kjm 42's Avatar
thanks once again lt80.
kev.
Old Apr 28, 2009 | 11:28 AM
mbriggs's Avatar
kjm 42...did you solve the ticking problem? I have the same issue.
Old May 12, 2009 | 11:28 AM
SnPaC's Avatar
thankyou,
kev.
What is that rear grease nipple for? i noticed it, but it was not shown in the manual...thx
Old May 12, 2009 | 07:30 PM
LT80's Avatar
LT80 Expert
It greases the axel bearings. It may take alot of grease.
QuadRiders
Oct 22, 2015 04:13 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
Bergmann
Aug 13, 2015 03:51 PM
MNatv89
Jul 7, 2015 11:36 AM
