84 trx 200
Old Jan 12, 2009 | 08:37 PM
stevenholub2719's Avatar
Default 84 trx 200
first of all my valves are ticking after a rebuild so i adjusted them alittle tigher then i would idle down really slow and die out.
second was i suppose to put sealer on my head gasket when i installed it cuz i think its leaking oil from there. there is oil bubleing around the head gasket.
the carb is rebuilt i installed a new 0.20 piston and rings and replaced all gaskets , changes reeds and bored the cyclinder.
everything is on time but cant seem to get my valves set right i adjusted the valves at 0.003. is their a special way to adjust them.
i lined up the t mark on flywheel and mad sure it was on the compression stroke and everything just cant seem to get the ticking to go away.
an answer will be appeciated.
Old Jan 12, 2009 | 09:35 PM
budedm's Avatar
Default 84 trx 200
Did you do a valve job? You may have worn rocker arms. They are easy to replace.
Old Jan 13, 2009 | 08:38 AM
Default 84 trx 200
i put new reeds thats all
Old Jan 13, 2009 | 08:44 AM
budedm's Avatar
Default 84 trx 200
Oh, sorry, I thought it was a 4 stroke.
