2003 700 Sportman no spark help
Old Jan 14, 2009 | 11:43 AM
03Polaris700Sportsman's Avatar
Default 2003 700 Sportman no spark help
I have a 2003 Polaris 700 that has no spark. It started with the engine just dieing for no reason to no spark at all. Any Ideas? Thanks for any help or ideas.
Old Jan 14, 2009 | 11:52 AM
I guess I should add that it has a new battery, fuel and plugs. It cranks but just has no spark.
Old Jan 14, 2009 | 01:45 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
easiest thing to start w/ is to make sure there isnt any part or wires that chaffed and is grounding out. so i am assuming that is turning over good where you posted it cranks.
Old Jan 14, 2009 | 01:51 PM
yep turns over just fine. I have traced wires for breaks and grounds and still no spark. Any Ideas?
Old Jan 14, 2009 | 01:52 PM
<div class="FTQUOTE"><begin quote>Originally posted by: 03Polaris700Sportsman
I guess I should add that it has a new battery, fuel and plugs. It cranks but just has no spark.</end quote></div>
Check under front panel,If you have the DUCATI coil pack that says made in Italy probably the cause if you have no spark! They are bad about going out! Best to check out stator just in case,but from my experience I havent had any bad stators just bad combo coil/cdi units.Replacements are supposed to be improved?
Old Jan 14, 2009 | 01:58 PM
great thanks for the help. this has got me pulling my hair out! It has alway ran great. just to let you know.....it shut off on me a few times before this. I was riding and everything was going good then its like someone just shuts the key off. then it progressed to no spark at all.
Old Jan 14, 2009 | 02:00 PM
where might I find a replacement? other than the dealer.
Old Jan 14, 2009 | 02:10 PM
I dont know of any after market suppliers,but wouldn't hurt to check around. Check stator and any loose wiring before you order parts,just to be on the safe side!
Old Jan 14, 2009 | 02:15 PM
great. thanks old polaris man.
Old Jan 15, 2009 | 11:17 AM
hey old polaris tech? So I called a few dealers to find out the pricing on a replacement coil and a couple of them said that they would lean more towards a stator than a coil. Any Ideas before I spend money or would you replace the coil first?
