Old Polaris Tech! Need help with bogging 1994 Trail Boss
Old Jan 16, 2009 | 12:22 AM
dgilfillen's Avatar
Default Old Polaris Tech! Need help with bogging 1994 Trail Boss
Hello,
I have a 1994 Trail Boss, that ran great until today!
I get home from work, fire up the wheeler, which had sat outside in 5 degree weather and wind... but it has been that way for 2 days here.
Anyway, when I fire it up, it bogs down like crazy!
I took off airbox, and when I rev it, gas droplets spray back into airbox. I tried disconnecting rev limter, no help.
I changed plug, no help. I thought maybe choke plunger was not springing back, but I verified that it is.
Here is one more clue: when I turn the fuel petcock off, and it runs out of gas, then it revs fine until right before it starves for fuel.
Another item I finally got my kids to tell me: they ran it out of gas today, and filled it back up. But, they said it ran fine after that.
ANY ideas as to why it would have ran fine last night and be getting "too much" fuel today?
Thanks!
dgilfillen
Old Jan 16, 2009 | 12:35 AM
dgilfillen's Avatar
OPT,
Seems like the only logical solution is a piece of crap in the rubber-tipped float needle valve? Or maybe it just could not handle the cold one more day!?
I guess the fuel level might be rising too high, causing all the fuel spray and too much fuel.
It would also explain why it runs fine when I turn the petcock off... at least until it totally runs outta fuel.
I will check the rubber tip on the needle, and let me know what else you think it might be!
Thanks!
dgilfillen
Old Jan 16, 2009 | 12:41 AM
eggenz7's Avatar
your float level could be slightly off but more than likely it got a peice of trash on the needle valve
Old Jan 16, 2009 | 01:02 AM
gaugedholes's Avatar
yep i would clean the carb.....good luck
Old Jan 16, 2009 | 08:04 AM
ftwflh's Avatar
I would leave it alone until it warms up.Cold can mess lots of things up
Old Jan 16, 2009 | 10:36 AM
dgilfillen's Avatar
Hey guys, I found this post:
http://forums.atvconnection.co...cleaning%20carburetor
where it talked about carb vent lines to the gas tank. Maybe one of these was plugged... as it seems as if these cannot vent, the carb cannot vent excess gas and it floods itself.
I will try these as well.
Thanks again for your continued responses.
dgilfillen
Old Jan 18, 2009 | 12:21 PM
dgilfillen's Avatar
bump
Old Jan 18, 2009 | 03:24 PM
ftwflh's Avatar
Loosen the gas cap and see what happens
Old Jan 18, 2009 | 04:40 PM
dgilfillen's Avatar
SOLVED!
I disassembled the carb, and found the main jet lying in the bottom of the bowl!
Thanks for everyone's help!
dgilfillen
Frisky2050
Apr 9, 2020 11:19 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
