2001 Raptor 660 starting problem
Old Jan 18, 2009 | 05:54 PM
WAS_P1FOXRIDER's Avatar
Default 2001 Raptor 660 starting problem
could some one please look at there starter relay and tell me if it contains 2 fuses or just one....
i dont know what else to do, i installed a new starter clutch and 52 tooth gear, new battery, new spark plug, and i pulled the plug to check for spark, i also tore down and cleaned the carbs, i don't know what the problem is
i can pop the clutch to start it, put it will not idle, so i have to keep thumbing the throttle
by the way as my name states i forgot my password and my e-mail changed
Old Jan 18, 2009 | 06:41 PM
Dune Rat 2008's Avatar
I have an 05 raptor and the relay only has one fuse in it and did you check your coil also and you may need to adjust your needle for the right fuel mixture
Old Jan 21, 2009 | 10:57 PM
miker660r's Avatar
adjust your valves
Big600twin
14
Jun 16, 2015 09:30 AM
Jbird4681
Jun 9, 2015 01:59 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
