Lt 80 pistons
Old Jan 19, 2009 | 11:41 AM
coastga's Avatar
Default Lt 80 pistons
I just tore down my son's 2000 LT 80 and the cylinder is scared where it blew the cylinder gasket. I'm looking of going back with OEM parts, but Suzuki has them listed like this:
SKU: 12100-40B00-100
PISTON SET (OS:1.0) OPT
or
SKU: 12100-40B00-050
PISTON SET (OS:0.5) OPT
Back in the old days, you could specifiy ten thousands over or twenty thousands over etc. What is OS 1:0 or OS 0:5? What do I need to tell my machinst to bore the cylinder? IS OS 1:0 twnety thousand over standard with OS 0.5 ten thousand over standard?
I think on my last post it was recommended that I torque down the cylinder and head to 105lbs; Is that correct? It seems like that is a lot of torques for such small clyinder bolts.
When it blew the cylinder gasket the head bolts were so lose that I almost could unscrew them with my fingers. Scary!
CoastGA
Old Jan 19, 2009 | 12:48 PM
95wolv's Avatar
I believe the factory calls out in mm, not thousandths, so the 1.0 is 1mm over stock,and the .5 is .5mm over. You would have to convert to SAE to get that in thousandths. Get a hold of LT80 on the forums, his name is Jack, he will get you going in the right direction.
Old Jan 21, 2009 | 11:03 AM
LT80's Avatar
LT80 Expert
95wolv is correct on the sizing.
What you do is get the piston and the guy bores/hones the cyl to the piston. You cannot just tell him to go to .xxx big.
Old Jan 22, 2009 | 10:32 AM
LT80's Avatar
LT80 Expert
oh yea, 115 inch pounds on the head nuts.
Old Jan 22, 2009 | 12:11 PM
onebigzj's Avatar
inch pounds not foot pounds!!!!!!!!!!!!!!!!!
BIG DIFFRENCE. [img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 22, 2009 | 12:14 PM
onebigzj's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: coastga
i think on my last post it was recommended that I torque down the cylinder and head to 105lbs; Is that correct? It seems like that is a lot of torques for such small clyinder bolts.
CoastGA</end quote></div>
thats what I was refering to. seems he thinks foot #
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
