Dinli Helix 90 Choke Upgrades???
Old Jan 27, 2009 | 03:56 AM
81dmc12's Avatar
Default Dinli Helix 90 Choke Upgrades???
hello,
i have a dinli helix 90 that the electric choke has never worked, i believe. i tested everyway i know how. does anyone have any idea how to fix this problem with a manuel choke i'm done with this one. i didn't know if other models would crossover, because the company is no longer. i know for a fact that a 2003 polaris predator 90 stator will work on this model, same color wires and connector. i not sure if the choke is the same??? any ideas and any replies would be appreciated.
thanks,
81dmc12[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jan 28, 2009 | 03:09 AM
81dmc12's Avatar
the 4-wheeler runs, idles fine once you finally get it started with starting fluid. runs great, it will pull my 225 lbs. around no problem. so, i'm thinking choke.
thanks again,
81dmc12
Old Feb 4, 2009 | 06:39 PM
hotblooded's Avatar
I have heard of alot of people switch over to manual chokes. I am not sure if a predator or Eton would work but I know that there is a way to switch them over. Find another brand that runs the same carb and do some switching.
Old Feb 5, 2009 | 02:05 AM
81dmc12's Avatar
thanks hotblooded,
i have been reserching, i guess i'll type some numbers on the web and see what comes up. if i find out anything i'll let people know what will work.
thanks again,
81dmc12
Old Apr 18, 2010 | 04:12 PM
stwining's Avatar
Too funny, pretty much exactly what I am looking for . I am having the same exact problem. Electric chocke has never worked since new. I also use starting fluid and once it warms up hauls my 220 lbd *** around just fine. Please let me know what you find and I will do the same if I cand find a solution and or a replacement manual choke.
Old Apr 19, 2010 | 06:58 AM
LT80's Avatar
LT80 Expert
Usually a new carb is in order.
Try WRHracing.com or Hetrickracing.com
They should be able to help you out.
Old Apr 19, 2010 | 01:23 PM
Toby Cheeseman's Avatar
You may want to try Maximum RPM as he was the guy in US for Dinlis. www.maximumrpm.com try him for your Dinli needs.
Old Apr 21, 2010 | 06:11 PM
HASBEENTTDUNER's Avatar
If it is the choke and you have the stock airbox you can reach under the fender and cover the airbox intake tube with your thumb to fire it up untill you can replace the carb.
Beeline08
Nov 11, 2016 04:00 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
