more power for 420 rancher
I was wondering if a mudslinger pipe and a programer wuold help me add some power. I'm running 27s and 2" lift kit. The other thing is when I'm climbing over logs on the trail or going over deep ruts the swing arm extends and is locking up the rear brakes. Have already loosened up the brakes, still same problem. The best thing about the lift is the wheelies I can do now.
did you notice any power gains with pipe and programer. The problem with the brakes is that the lift has the cables stretched and when you gas it the bike lifts causing the swing arm to pull the cables harder. Thought about installing a limiting strap on shock like some lifted trucks. Just a thought.
the PCIII will work with any pipe, or even no pipe atall. but best gains will be with an aftermarket filter and pipe.
are you maxed out of brake cable adjustment??? thats the only reason ik of that the cable would be to short...
Ya did notice a difference, well the Rincon PCIII have diff programing like Mudslinger+aftermarket filter, HMF+Aftermarket filter, but the 420 Only has a programing for the HMF not a mudslinger.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Elkaholic
Sep 6, 2015 02:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
