how to wire pia lights
Old Feb 2, 2009 | 06:19 PM
loaderboy's Avatar
Default how to wire pia lights
If any of you guys that have those pia round off road lights on your xp could you please tell me how they were wired. i am going to turn them on and off with a switch. thanks!!!!!!
Old Feb 2, 2009 | 07:55 PM
randymack's Avatar
Banned
yeah i plan on doing this soon as well. pics would be great if you can!
Loaderboy any pics of your setup? will you post when its complete too? thanks.
Old Feb 2, 2009 | 08:44 PM
loaderboy's Avatar
i have to wait for my brushguard from the atv guru. he is welding on some tabs to mount the lights. it sounds like there is a big backorder to get one. it might be a while.
Old Feb 2, 2009 | 10:20 PM
randymack's Avatar
Banned
i went with these for my lights:
http://www.jcwhitney.com/PIAA-...3+600018460_10113.jcw
what are you using?
Old Feb 2, 2009 | 10:31 PM
DavidXP's Avatar
do you guys find these very bright i find the 40% less than the headlights i am NOT a fan!
Old Feb 2, 2009 | 10:51 PM
randymack's Avatar
Banned
which do you have david?. I have the 520 ATP (Xtreme white H3 85 watt comparable 135 watt bulb)
its not the "brightness" i was needing but the specific off-road "pattern" these give.
designed specifically for off-road trails. which i ride in the dark sometimes.
Old Feb 3, 2009 | 03:43 PM
DavidXP's Avatar
i have the ones that came with the LE model[*]Name:  quadandsuch056.jpg
i find them way too dim the look fantastic but for that price they should be brighter can I change the bulbs??? in this pic you can actually see that their dimmer
Old Feb 3, 2009 | 03:59 PM
Hotdogmb's Avatar
How much were those hand guards and do you have the part #. Thanks.
Old Feb 3, 2009 | 06:35 PM
loaderboy's Avatar
thanks David, if you happen to have to remove your pod or front rack could you let me know what wires that the lights are hooked to. thanks
Old Feb 3, 2009 | 08:02 PM
Bytor's Avatar
I just installed the lights this weekend. If you use the Polaris wire kit, the power hooks right up to the battery. There is a split in the power wire that goes to the switch. As an FYI, the switch that comes with the kit is a generic round white one. I bought the switch used for the LE models. Looks a lot better.
