06 polaris 700 efi won't start
If machine has been sitting for 3 months and battery not kept at a constant charge along with stale gas can contribute to problems. Batteries loose 1% charge daily under non use and gas can go bad in as little as 2 months. Make sure battery is fully charged, then can try a little contact/electrical cleaner into air filter to see if helps boost off and runs on its on.Also do you hear fuel pump prime up?
thanks, I was starting it regularly, until the battery went dead, I have not had time to ride lately so i guess it was not running long enough to keep battery charged. fuel pump is priming and i did have stabil in the gas
If it's getting gas and spark then check your fuses, if fuses are ok then check crank sensor after that check you ECM, mine went bad. You can tap on your EMC with a screwdriver and if it starts then that it...
whitty
67
Feb 24, 2021 02:52 PM
