2004 330 magnum 4x4 4-wheeler
Old Feb 11, 2009 | 07:39 AM
dority60's Avatar
Default 2004 330 magnum 4x4 4-wheeler
4- wheeler starts right up idles good,pput on throttle,back fires and dogs out till it quits,
Old Feb 11, 2009 | 07:49 AM
eggenz7's Avatar
try pulling the black wire from the rev limiter box. its usually located under the *hood* piece on the front of the motor.
try changing the spark plug. could be shorting out when under compresssion.
check all your grounds good.
give the carb a deep cleaning
change your fuel filter/and your fuel.
just a list to get you started. start wehre you want.
Old Feb 28, 2009 | 11:13 AM
dority60's Avatar
there is no black wire on the 330
Old Feb 28, 2009 | 11:14 AM
dority60's Avatar
do you know the settings on the carb, thanks
Gwolf228
Feb 18, 2017 01:36 AM
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
