Help!! Still jetting Raptor
Old Feb 9, 2001 | 12:54 PM
swytak's Avatar
Man!!! I have read 14,000,000 posts on this already and still can't seem to get it dialed in. I have a FMF power core 4sq slip-on and cut the flaps out of the snorkle. I put in a new plug and did 5-6 full throttle plug tests. The ceramic portion of my plug is still white. I am using 150/155 mains and 27.5 pilots. I just can't imagine that I need to go bigger with just a slip-on. I have noticed that when running full throttle and letting off (far a second) and hitting full again, it pops and then goes again. This is a lean condition. Isn't it? I have checked the clip position and it is in the 3rd from the top position. I can't imagine that I should need to go bigger or move the clip. Anyone with thoughts? Your help is appreciated.
Thanks for answering the 14,000,001 jetting question.
Old Feb 9, 2001 | 01:06 PM
ccarpe1's Avatar
I am surprised you had to do anything at all with just the slip on. I am also looking at the FMF slip on. Keep us posted.
No2StrokeBs's Avatar
I have yet to mess with my clip position or mixture screw and mine is running great.I think the Raptor is lean form the factory. I put 150,155 jets in mine with no mods at all and it smoothed it out a lot and even picked it up some, so you might still be on the lean side.And also, start jetting to high and work your way down, this saves a lot of time.Try a 160,165.That is the most you should need, then work your way down.
Old Feb 9, 2001 | 02:26 PM
bash's Avatar
It's removing the snorkel flaps, not the silencer that causes it to lean out so much.
Old Feb 9, 2001 | 02:32 PM
ccarpe1's Avatar
Bash, it's hard to believe just those two flap removals would cause us to have to re-jet. Ahhhh...I better check my plug.
Old Feb 9, 2001 | 04:14 PM
rigoni's Avatar
I have a question? When you are gasing it and let off and it pops, doesn't that mean it's rich. I say this because I recently ran from about 1,500 to 6,700 feet. When I got higher the air gets thinner, the engine is running richer. Let me tell you it was poping alot. I might be wrong, can someone varify this.
Thx,
Old Feb 9, 2001 | 07:17 PM
Sandgod's Avatar
Swytak I ride at 4800ft and am running 145 and 150, clip in number four position, w/ full Big Gun, holes in air box and flaps cut out. You need to go up on your jetting beacuse you are alot lower then us. My brother tried a 150 and 155, ran to rich.
Old Feb 9, 2001 | 07:33 PM
KyRaptor's Avatar
I tend to believe the popping comes from a rich condition as you have noticed. I ran my mains all the way up to 200 before it actually cut out and fouled the plug.. But it was way rich. It seemed to me the richer I got it the more mid it has but I lost the top. Mine felt like 5th gear was an overdrive. I started back down until I felt 5th gear really pulling hard and stopped.
I have a feeling that most of the jetting going on is way on the rich side. Time will tell. When I had the lid on and full exhaust I ran 150/155 and it felt okay but looking back I think it was rich. It seemed like it coasted in 5th.
Old Feb 12, 2001 | 03:13 PM
swytak's Avatar
Thanks fella's, I just picked up 160,165 and 170 mains. Will install and test tonight. Also picked up 6 1" univents for the lid. So if I can get it rich enough with 165/170 I will install the uni's. Let ya know tomorrow.
Thanks for the help.
Old Feb 12, 2001 | 03:58 PM
BlueLeader's Avatar
Question...before taking my carbs off, what style of jets does the Raptor have? My brilliant Yamaha counter clown didn't know!!! Round or hex??
thanks
