I got 2 ???'sss
Old Feb 9, 2001 | 08:07 PM
hondaboy5's Avatar
I was wondering if they make a clutch kit for a 2001 Lakota.What's the diffrence between supertrapp IDS2 quite series and and the racing pipe is does the racing pipe give it more power or just sounds a lot better
Old Feb 10, 2001 | 06:45 PM
Warrior1369's Avatar
I'm pretty sure the racing pipe adds power and I know it's significantly louder, plus its cheaper.
Old Feb 12, 2001 | 10:22 AM
mojaveaddict's Avatar
the race pipe is a "Straight through" design where the quiet series is not. The quiet will only flow so much. After about 10 disc adding disc will not increase the flow. With the racing pipe the more disc you add the more the flow and the louder it gets. If you only plan to mod with just a pipe, jet and better air filter the quiet pipe will not be that bad. but if you plan to race or go more extreme with your mods moving the power band up in the rpm range then you need the race series. By the way the quiet seies works really good on the lakota.
