2001 Scrambler 400 2x4
First of all I am new here so bear with me. I recently aquired a 400 Scrambler and I am having a little trouble. The bike runs great with about 1/2 throttle but it cuts out at full throttle. I am kind of thinking it is the jetting but I would really like some opinions. I am having problems with the throttle cable sticking because part of it was rusted, I have a new one on order, but I don't see how this could be the problem. Also the oiler is not being used the guy I got it from said it didn't work but as far as I am concerned I would rather mix my own gas anyhow. I am thinking this may be the problem I have heard that if you unhook the oiler you have to jet it different. Is this true and what do I need to rejet it too, elevation is not an issue I am in Oklahoma? Also I would like to know where I can buy the oiler block off kits I went to the hot seat website and they are like $35, can't you get them cheaper. Is not having the oiler blocked off a big deal, at least until I get a block off kit which will be as soon as possible? I am mixing my gas at 40:1 is this right that is what I always used on my dirtbikes or is this wrong and making me foul the plug? Any input would be greatly appreciated. Thanks.
i would clean your carb really good. sounds like a port is clogged causing it to bogg at full throttle. the jetting doesnt need to be changed if you premix. no need to get a block off kit. take the oil pump off and pull the shaft out of the hole and then put the pump back on. and the 40:1 mix is fine as long as its not bored or ported (bigger surface area and it would require more oil)
The carb looked clean when I took it off before but I will take it off again and make sure that all the vents are clean and everything. Thanks for the help I will let you know if it doesn't work.
Take the jets out and clean them,be sure the air filter is extremely clean.If this doesnt fix let us know
Okay sorry it took me so long I had to wait for my throttle cable to come in. Well I have cleaned the carb and no luck. I am wondering if this could be because of the reeds or something like that? Are these powervalve motors? The guy I got it from said he put new reeds in it but I have not checked them. Thanks.
is the exhaust clogged up?
have you checked your clutches to see if they have any wear? they tend to control RPM's too
I haven't checked the clutches or the pipe. I guess if the clutch has wear it will be noticeable? I do get a back fire every now and then if that helps at all. I have not found any air leaks or anywhere that it could be sucking in any extra air either.
