Polaris trailblazer pull start
Old Feb 22, 2009 | 04:25 PM
kilwees11's Avatar
Default Polaris trailblazer pull start
Anybody know how to rewind a pullstart rope i cant seem to get tension on it?
Old Feb 22, 2009 | 05:06 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you make sure the spring wasnt broke or unhooked?
Old Feb 22, 2009 | 05:13 PM
kilwees11's Avatar
no where do you check to see if the spring is unhooked?
and thanks for the quick response as i am working on this as we speak
Does the tension go to the right or left it seems the right but im not sure
Old Feb 23, 2009 | 08:00 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the spring should be under the recoil. when you pull the rope little dogs extend out to catch the starter and turn over the crank. when you pull on the rope it should show you which way it goes as it would be tightening up the spring when its pulled then when you let the rpe back in the tenion should unwind on the spring causing the rope to go in. hard to explain but if its off in your hands you might be able tyo tell better. imo.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Dammar
Nov 14, 2015 07:41 AM
Scott-Leigh
Jun 6, 2015 09:10 AM
FourWheelOverTwo
May 31, 2015 07:26 PM
1000gade
May 27, 2015 12:37 PM
