DRX 50 top end tech
Old Feb 23, 2009 | 08:27 PM
Team Wolf Pack's Avatar
Default DRX 50 top end tech
Does anyone have the cylinder head tourqe spec's for a water cooled 2008 drx 50. I am going to rebuild the top end for the first time and could use some tips.
We have raced 2 seasons on this bike and it is stock except the wheels and air cleaner
Old Feb 24, 2009 | 07:09 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
I torque the head nuts to 115 inch pounds.
Old Feb 24, 2009 | 07:15 PM
thanks that will help alot, Is there a tech site that I could go to for referance for other stuff like omitting the oil injection and removeing the oil pump gears. My son loves to get the hole shot.
Old Feb 25, 2009 | 10:03 AM
LT80's Avatar
LT80 Expert
atvriders.com (mini section)
miniatvtech.net
Old Mar 1, 2009 | 11:37 PM
thanks, in the kit that I got it has the piston, two rings,an ochtagonish ?spring ring thing?, wrist pin, clips and a couple gasket . What is the ochtagon springy thing that was not on my stock set that was on the bike.?
Old Mar 2, 2009 | 07:13 AM
LT80's Avatar
LT80 Expert
If it's what I'm thinking, the LT80 stock bore piston has that thingie too. You should find out which ring it goes under. I'm thinking the top ring.
Old Mar 5, 2009 | 07:57 PM
I got it back together and did not use the thingie but broke one of the rings and ended up putting the best use ring out of the old set. it rens great. At half throdle it has almost the same as before. Cant wait to open it up.
speedbuff
13
Nov 11, 2020 10:16 AM
r1pilot83
Sep 27, 2015 07:38 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
rgjackson
Sep 17, 2015 11:21 AM
blueandy88
Aug 31, 2015 12:42 PM
