200cc atv wont start engine wont turn
Old Feb 23, 2009 | 09:34 PM
tja349's Avatar
Default 200cc atv wont start engine wont turn
When u try to start it the motor jut churns a little bit and never turns over... when it first happened the engine was a little warm and i was able to catch it in gear now thats its been sitting i cant catch the gear or use the electric starter.. fan and lights work fine - is it maybe the starter?
Old Feb 24, 2009 | 12:08 AM
LynnEdwards's Avatar
Electrical Expert
Looking at your previous posts on the same issue, it seems that the problem is that the starter turns but the engine does not. Am I correct? If so, you need to change the starter clutch.
Old Feb 24, 2009 | 08:06 PM
tja349's Avatar
Yea thats right i have a recording of the noise that someone else wanted to hear if u would like to. Is the starter clutch expensive? And are they hard to change?
Old Feb 24, 2009 | 10:54 PM
Electrical Expert
I'm not familiar with your specific engine, but usually the starter clutch is easy to change. It sits in between the starter motor output shaft and another shaft that turns the engine. It is usually accessible under an outside engine cover. You may want to look at it first before going out and buying one. It may just need cleaning up and some oil.
Here is a thread from somebody else with a different engine with the same problem:
Starter Clutch Problems
Old Feb 25, 2009 | 06:52 PM
tja349's Avatar
There is a cap and under it is a little gear that touches the starter and goes into the engine is the gear the starter clutch? Do u know where to get the parts. Thank you for the help
MikeyBoyesq
Nov 27, 2020 02:44 PM
Thanos
Jul 12, 2015 08:40 PM
alix
Jun 28, 2015 03:28 AM
1000gade
May 27, 2015 12:37 PM
elmer119
May 24, 2015 10:51 AM
