07 800 X2 will not start
Old Feb 25, 2009 | 08:22 PM
Sportsman X2's Avatar
Default 07 800 X2 will not start
wahsed my bike today after mudding yesterday it will only start if i give it gas and will not idle.... i believe something got wet any advise
Old Feb 25, 2009 | 10:07 PM
eggenz7's Avatar
efi or carb model? if its carb you could have a piece of dirt clogging a port.
dont have a clue if its efi
Old Feb 25, 2009 | 10:30 PM
its the efi model
Old Feb 26, 2009 | 06:55 AM
Kerbbirds's Avatar
Get some dielectric grease and start unpluggin, cleaning and greasing wires, start at t-bap sensor under seat, might even pull sensor and see if the end is wet. Also take both spark plug wires off and grease them, Ive seen them get wet and cause a miss.
Old Feb 26, 2009 | 06:58 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
agree w/ what kerbbirds said and maybe check to make you didnt get any water in while you were washing it. i have pressure washed mine serval times w/out any issue so its going to be minor most likely. when its all dried off does it start fine? is the feul pump turning off(primming up) when you turn the key on as well?
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
