Big red won't start
Old Feb 27, 2009 | 06:28 PM
rogopop's Avatar
Default Big red won't start
Hey
I have a '85 Big Red 250 ES. Last summer the starter burned out. I just put in a new starter and battery but it won't start when I press the start button. It will kick start and it will start when I short the terminals on the relay. Everything seems to work when it's running (headlights hi & lo, neutral light, reverse light)
Any suggestions on what could be the problem?
Thanks
Old Feb 27, 2009 | 10:33 PM
snorulz's Avatar
bad switch or relay? Did you check to see if you have power at the relay from the switch? Is it not cranking at all or does it crank and just not start?
Old Feb 28, 2009 | 07:25 AM
rogopop's Avatar
How do I check to see if I have power at the relay from the switch?
The engine will crank and start by jumping the battery and motor terminals. every thing else is so closed up that it's difficult to get to.
Old Feb 28, 2009 | 05:00 PM
rogopop's Avatar
I tracked it down bit by bit.
It was a bad connection at the fuse.
Now it starts like new.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
