Son of a...
Old Mar 2, 2009 | 11:19 AM
Schickie's Avatar
Default Son of a...
Was just out with the Foreman and it was slightly stuck on a ledge.
Bounced once, bounced twice, POP! and going nowhere. Thank goodness still in the yard playing in the snow.
Does anyone have suggestions? Axle, gear, drive shaft?
Old Mar 2, 2009 | 02:02 PM
12guns's Avatar
Default Son of a...
Don't know for sure, but check cv shafts first. Will be visible from front underneith. Then move on the u-joints. With large tires and a lift, the u-joints have alot of strain. If/when you find the problem, but a beefier part that will match the lifted and strained bike. Good luck!
Old Mar 3, 2009 | 07:34 PM
Sisco1957's Avatar
Default Son of a...
I saw one a couple of weeks ago where the splines on the axle were almost stripped. Remove the filler plug on the rear differential and see if the ring gear is turning. If it turns when You put it in gear with a little throttle and the axle doesn't the splines are stripped. If nothing is moving I would check the clutch. Hope this helps.
Old Mar 4, 2009 | 10:17 AM
trailbuzzer's Avatar
Default Son of a...
Hey Sch
What did you find??
Old Mar 4, 2009 | 09:48 PM
Schickie's Avatar
Default Son of a...
Tearing it down tomorrow. Been azz deep in snow for two days here with no garage. Weather's starting to cooperate.
Sisco, I'll try that diagnosis and let you guys know. Thanks for the suggestion.
kingoddball
1) Engine problems..
16
May 13, 2017 09:37 PM
JohnnySplat
May 2, 2007 10:31 PM
squeege
Apr 21, 2006 04:18 AM
Ginnis
Where to Ride
Oct 26, 2005 09:18 PM
pinheadedjoker
Aug 14, 2004 10:17 PM
