New YFZ 450 Pipe and Jet Question
Old Mar 4, 2009 | 07:10 PM
lx12ringer's Avatar
Default New YFZ 450 Pipe and Jet Question
I just bought a new YFZ 450 and I've got FMF pipe coming for it. Will I need to rejet it when the pipe is installed? Thanks
Old Mar 4, 2009 | 07:59 PM
Dune Rat 2008's Avatar
to make it run at its best you probably should but i dont think you have to do it
Old Mar 5, 2009 | 04:34 AM
Jojo-YFZ-ESR's Avatar
if you leave spark arrest in it then no, but the yfz is easy to jet, you know u want the extra power
Old Mar 5, 2009 | 08:03 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
Yes you have to. If you don't your yfz will have more flow than factory. It's already slightly lean at factory jetting. More air + less fuel = running hot.
Besides that if you don't you just spent that money just to change the sound. You won't get the amazing power increase without changing the jetting. It's not hard at all. Go ahead a pick up a air filter kit to replace the crap yamaha one and rejet. Your jaw will drop when you find the difference these 3 simple things can do.
Old Mar 5, 2009 | 05:55 PM
91Warrior357's Avatar
sometimes if you buy an aftermarket pipe you can get away with running it without rejetting but if you change your airfilter to an aftermarket one or you run it without the lid then its very important to fatten it up, running your bike to lean is not a good thing, its better to be rich than lean.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
bvolks
Sep 13, 2015 12:57 PM
Bigtwin700
Sep 9, 2015 09:32 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Brandon400
Sep 5, 2015 08:44 PM
