Polaris scrambler 400
Old Mar 7, 2009 | 04:43 PM
hondafl350's Avatar
Default Polaris scrambler 400
Hi I have a 1998 Polaris scrambler 400 4x4 and I bought it in peaces. I have almost put it all back together but I have run in to a problem with the clutch cover. The primary drive clutch is rubbing on the front bottom of the cover. I have no idea whey this is happening. Is their an adjustment for the cover or for the engine?
Thank you very much for any help!!!
Old Mar 7, 2009 | 05:34 PM
Turboman412's Avatar
no cover is warped. or backing plate. replace both
Old Mar 7, 2009 | 05:51 PM
If backing plate has a small bracket at front(model years were different) can loosen bottom bolt and possibly move one way or the other to quiet noise. IF not then check motor mounts. Backing plate and seal on tight?
Old Mar 7, 2009 | 10:07 PM
hondafl350's Avatar
Thank you I looked at the cover and it looked like a belt had jumped off on the driven clutch and hit the cover pushing it backwards bending the brackets so I just bent them back and it is clearing it for the most part now.
Think for your help
scram5050
Aug 30, 2024 01:39 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 14, 2015 12:11 PM
maxjung
Jul 14, 2015 03:10 AM
maxjung
Jul 13, 2015 05:11 PM
