99 Polaris Sportsman 335 4x4
Old Mar 9, 2009 | 09:05 PM
branden77's Avatar
Default 99 Polaris Sportsman 335 4x4
It has the axel that has ujoints. The one yoke broke at the wheel and I replaced, and now I have a bad wobble in that wheel. Everything seems to good, I have checked everything the only thing I think it could be is the out sleeve I bought it used, Can anyone help me.
Old Mar 9, 2009 | 09:37 PM
Blackhills's Avatar
I had a wobble in my front wheel after I took it apart to check the bearings and found out later that you need to torqe the nuts that hold your front wheel on 12-14 ft lbs. That was on my 99 sportsman 500.
Old Mar 10, 2009 | 07:39 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you check it for bad bearings? just a tought
Old Mar 11, 2009 | 05:07 PM
ESCAVADER's Avatar
Probably has a worn out aluminum hub on the end of the shaft.COMMON to go on the MAGNUMS ,Ive changed mine several times.Shafts are steel,hubs are aluminum.Designed like that because its positive trackion.If you ride on hard surfaces they wear out quick.Easy to fix,cost around 100 depending on year/RIM DESIGN.The ones on my 02 cost more than our 00.
ALAN
Jmuddin284
Jan 19, 2026 07:16 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
