starter engaging while running
Old Mar 10, 2009 | 09:47 AM
HARLEY_OWNER's Avatar
Default starter engaging while running
2 questions...
ok i know i seen a few posts on this but i couldnt find them.. i noticed while i was out plowing yesterday that i heard a couple diffrent times my starter clicking on for a second and stopping.. it did this two or three times...
also is it on all quads to sometimes pull hard one direction when in 4x4.. this happend before on my 94 and on this one...
Old Mar 10, 2009 | 10:28 AM
MEGA XP's Avatar
Can't really help ya with the starter engaging, other than to speculate that it might be a short somewhere. Like possibly jumping the selenoid. The pulling to one side in 4wd is common on machines with locked front diffs. One wheel will get more traction than the other, or you may have one tire aired up more than the other. If it does it all the time probably more serious.
Old Mar 10, 2009 | 10:52 AM
no it just does it once in a while.. if its in 2x4 it wont do it right...
if anybody knows a solution to problem one ... let me know
Old Mar 10, 2009 | 12:03 PM
MEGA XP's Avatar
NO it should not do it in two wheel, if it does it's the roller cage or "magnatized armature plates. Was it wet snow? Did it do it when sitting still or moving more? When on throttle or off throttle? Maybe try flagging the title "Please Help Old Polaris Tech" see if he's heard of this.
Old Mar 10, 2009 | 04:36 PM
bump...
looking for answers on the engaging issue thanks boys
Old Mar 10, 2009 | 07:14 PM
Have had solenoids short out engaging starters customers have had to disconnect batteries!,Plus check starter bendix also. awd locking probably because of magnetized/worn armature plate. Replace both as the other side will go also,sooner or later.
Old Mar 11, 2009 | 05:36 AM
hobbles's Avatar
Mornin HARLEY_OWNER
I had that problem a while back and made a post bout it.
http://atvquadsquad.com/eve/fo...466018454/m/7741007855
supermanotorious
Mar 12, 2021 11:02 PM
Rooky
10
Jun 23, 2015 09:35 PM
Big600twin
Jun 10, 2015 03:01 PM
leenover
Jun 5, 2015 09:50 PM
bbehrendt
May 28, 2015 09:25 AM
