Cooling Fan Motor for 06' AC 400
The cooling fan motor is starting to make a squealing noise a few seconds each time it cycles on then noise goes away , just started doing this the last time i rode it and was wondering if anyone has had to replace one ; and if so what did it cost to reolace !
Only interested in cost of the Fan motor i do my own labor , thanks in advance for any info on this subject ; O.E.M or aftermarket doesn't matter !........
Thanks alot cupsz71 i'll check with my AC Dealer freind to see if the 400 has the same size motor as the 500 ,650 and 700 uses , most likely it should fit i know that the 400 is the same size chassis ; but i'll check with her first just to be sure the heat sensor's are on the liquid cooled radiator model's before spending the $$$$ !......
TLC
Jul 11, 2015 02:28 AM
