best chain
Old Mar 13, 2009 | 08:23 PM
quadtarded1's Avatar
Default best chain
just wondering what chain people are using on a trailblazer and on the scrambler.. i need to buy new chains for both quads so i want to see what the better choices are.
Old Mar 13, 2009 | 08:34 PM
3_Polaris_ATVs's Avatar
Default best chain
Last ones I bought off ePay with the orings and have lasted 5 years. Make sure to check your sprockets also.
Old Mar 13, 2009 | 08:43 PM
Default best chain
Yea im replacing those too....i was thinking of going with sidewinder chain and spockets or D.I.D chain with what ever spocket i can find for 11 tooth and 38 tooth
Old Mar 13, 2009 | 10:20 PM
SSB CHAMP's Avatar
Default best chain
A sidewinder chain looks to be the best thing out there for a chain on the market
Old Mar 13, 2009 | 10:25 PM
eggenz7's Avatar
Default best chain
if you ride the mud very often do not get an oring chain.. the mud gets in there and eats the o rings away causing premature slack in the chain. a regular chain is the best thing for the mud. can get lube inside the rivets on those a lot easier than the oring chains. just my 2 cents.
Old Mar 14, 2009 | 08:15 AM
ftwflh's Avatar
Default best chain
I got a a DID Z ring chain the last time and it is holding up great.Before that I ran stock Regina Oring chains and got a couple seasons out of each of them.I just look on Ebay for the cheapest chain the correct size and make sure it is long enough.Have to cut to fit.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
