kfx pipe and air box info
Old Mar 15, 2009 | 12:35 PM
honda400exracer3's Avatar
Default kfx pipe and air box info
i have a 2003 kawasaki kfx and i just bought a big gun race pipe full system
will it hurt my motor and anything if i dont jet it
i am keep the air box on and everthing else is stock
Old Mar 15, 2009 | 09:54 PM
stillV1's Avatar
It is always best to rejet after an exhaust, they are set most times from the factory a tad lean for emissions and adding an exhaust will lean you out even more and this is bad for the motor! My advice would be to rejet and avoid any damage due to overly lean conditions. Just my 2 cents[img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 16, 2009 | 12:08 AM
jeffeosso's Avatar
at least go a full turn richer on your mixture
a pipe swap should always have a airfilter and dyno kit, which includes a new needle
bang for the buck is nearly ALWAYS the airfilter+dynojet kit+inline fuel filter
Old Mar 16, 2009 | 01:25 PM
ss97's Avatar
Lets Ride!
If you change the head pipe you are changing the back-pressure too much to leave the stock jetting. If you were just doing a slip-on you can get away without jetting. But he head pipe is where the power really comes into play.
Old Mar 17, 2009 | 12:08 PM
ok do you think it will hurt my motor if i dont rejet it and keep running it with the full pipe
do you think it will burn up my piston and valves
i have the air fillter on and cover
no other parts
Old Mar 17, 2009 | 06:02 PM
and what about my baffle on the stock pipe if I take that Out will I burn my valves up or piston?? dose it give me and extra profomance and power
do any of you know any other tips or trick to get more power and speed
or cheap mods
I got pipe full
I need the jets
I have to high flow uni air fillter
and 14-40 chain and sprockets.
and no braking brake
Old Mar 19, 2009 | 01:07 PM
or cheap mods
I got pipe full
I need the jets
buddieboy
Dec 9, 2016 05:50 PM
mrtidy
Feb 3, 2016 05:00 PM
exmotocrosser
Sep 26, 2015 08:18 AM
woodthings
Sep 25, 2015 05:58 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
